The metaltechs will be buying new material for welding inductions from https://www.metals4u.co.uk/
If you’d like to get in on combined shipping, now would be a great time. I will make the purchase on Thursday at noon.
yes, please… considering the shared delivery costs, this is cheaper than my local merchant.
I’ll send you my brass list by tomorrow.
Fed
Yeah, I’d like to get some aluminium rods for turning on the lathe…
Is this a good way to buy this or are there cheaper ways from scrap places, etc?
Just asking as I see that metal is actually quite expensive and not bought any before?
Hi Steve,
Metals4u is expensive compared to other online shops, I found “first choice metals” to have better prices.
Try also “The metal store” for steel.
Best, J
Thanks for pointing that out Joe!
Brass and Al are much cheaper at 1stchoicemetals.co.uk but our the 3mm mild steel sheet for the welding inductions is cheaper at metals4u than the metal store.
When prices were a bit crazier, the cheapest large round cutoffs of Al were on ebay from the US even including shipping. Not sure if that’s still the case.
Hi Kyle,
If you want to buy steel check https://www.actonbrightsteel.co.uk/ they deliver to London and I’m sure are less expensive.
You can find the odd bargain on ebay and if you are looking for something special check https://www.nogginend.com/ or google model engineer supplies.
Best, J
@Kyle I’ll pass this time, i’ve found out my local metal merchant is much cheaper for brass flat bars.
it’s https://www.metalsupermarkets.co.uk/ in Greenwich.
maybe check if it’s cheaper for mild steel too and i can go directly to pick up the order ( if it’s not going to weight a ton for my backpack)
It’s more expensive unfortunately…
I bought the steel for the RE from hardwareoutlets ebay store
I’ve bought some Aluminium from eBay links so I’m all good as well thanks
With these metal prices we should build an induction heater, or get a smelting furnace from vevor, and cast our alu brass and copper scrap into round ingoth, those are easy to make. we can collect the chips separately and pick up old taps and stuff to reduce the costs.
Sure, we already had outside christmas bbq so we are half way there
works the same way just have less power
I have completed the order. I’ve never tried it, but metals4u will apparently price match: https://www.metals4u.co.uk/our-price-promise
ah… if I knew i would have sent you the metalsupermarket prices to match
next time…
Hello. I need to buy some 4mm mild steel rod - only want 2m. Doesn’t anyone else want to purchase metal to make the most of the shipping cost? I’ll need to put an order in this week!
Yes please. I’ll let you know later when I’ve had a chance to look.
Hi @kimmik
Would you be able to add 500 x 500mm of this to the order?
https://www.metals4u.co.uk/materials/mild-steel/mild-steel-sheet/sheets/2501-p
Happy to pay up front
Glenn
Hi Glenn
Sure I can. Can I get it delivered to the Makerspace or is that a pain? Probably is…I live in West Dulwich so can arrange delivery to my address.
So doing the maths; the sheet is £14.95 + £2.99 VAT + delivery of £5.40 (£10.80 split between us). Total £23.34. Be great to sort payment up front. My email is kimthornton6@gmail.com if you want to continue that way. I’ll send you bank details and copy of order etc
best
Kim
