I’m making a variation of the handplane below, unsure how to create the angled cavity for the wedges slides down into…my blade is exactly the same width of the plane body so I need the hole to be centre and stay centred as it goes down…I guess I could make it a big bigger and give wiggle room for the blade?
Hi Afshind, if you dont feel the blade needs to be constrained too much sideways (wiggle room) then I would make one side open.
If you really want to keep to the drawings, then one approach would be to clamp it to a block at the correct angle then drill down with the pillar drill once a flat surface has been made for the drill to start on. I’d cut out the lower slot first though.
