Hi!
Looking for some advice on a clock idea.
I want to make a little jig that magnifies a Casio F91W watchface so you can see it from a distance and use it as a wall mounted clock. Ideally should have a pretty small focal distance from watchface -> lens so the finished item is as thin as possible.
In my head it’s basically just a magnifying glass, but the subtlety is with most I believe you need your eye to be at a specific distance from the lens, but I want to be able to see this from across the room.
Will this mean extra mirrors are needed, or surely there’s a lens made for purpose? Basically, I don’t even know what the right words to google are! Ideally would just buy the glass, but can deconstruct/modify an off-the-shelf product if that’s easier/cheaper too.
Cheers,
Sarab
