anyone made a long (1-2m) i2c cable - anything I should worry about? Can use normal stranded wire or should I think about cat5-esque twisted pairs? If so, how do I do that?
I2c analogue devices pdf
Shood take you to a good datasheet
Low C cable with a twist shood be ok for 1 or 2 m
Think cat 5 is about 50pF/m
http://tronixstuff.com/wp-content/uploads/2010/10/p82b715.pdf ?
This is for properly long cables!
Yeah says practical limit without that chip is still a few meters.
Probably got a loose connection then!
Seems to be about capacitance as @joeatkin2 says. Sound like you’d get a few metres out of 50pF/m cable
Or the cable has a high C there may be stray C around . Are you using twisted pairs ? If so is one leg of both pairs grounded?
I did use twisted pairs but in a totally uninformed way, just tied each pin to both wires in the pair… Better way?
That’s not going to work. One leg should be grounded at both ends, so you need two pairs
But a bit of ribbon might do better with a central ground
So I should have clock+gnd pair, data+gnd pair and vcc+gnd pair?
Vcc on its own
I used 20cm test wires before committing to pcb. A few blips with ic2 timing but worked in the end. Only thing I can suggest is make sure it works with short cable before faulting longer one.
