Hello @lasertechs the lens is not fixed to its holder. Nothing bad has happened, but it (gently) came out when I was cleaning it. I’m on the machine at the moment, but wanted to let you know so that it could be glued again.
Thanks!
Or if you can tell me what glue to use I’m happy to glue myself. I’m here…
Hi Gawain, it was epoxied to the holder.
If you feel confident, take some gloves on and grab the epoxy resin in the snug, mix tiny amount thoroughly and apply wth a toothpick. Read the manuol for ratios.
Otherwise Ill be in tommorow and can do, now at the Basel airport.
