Laser tool control doesn’t seem to be registering fobs - we’ve tried a couple of different ones. (Other people have reported 3D printer readers not registering either earlier today so might be a broader problem). Is there anything I can do to reset laser TC?
Plug off the mini usb wire on the side and plug it back, node will retry to connect with space WiFi and hopefully it will work, your can keep the door open for batter WiFi strength
Perfect - that fixed it thanks. Wasn’t sure if I was allowed to pull cable out.
In in double turn it off and back on again - restarting the PC (that powers it) also helps
