Hi @lasertechs
Just want to check we are okay to use laser mdf on the cutter as I cannot see it listed on the permissible or forbidden materials lists.
Here are two links:
Cheers!
Matt
Hi @lasertechs
Here are two links:
Cheers!
Matt
As long as its laser grade all good to use on the laser.
However please be vigitlant and do a test cut first whenever cutting a new material.
We also have a stock of laser safe ply available in the space. Stock can be found under the laser PC.
Thanks!
