Laser engrave glass settings?
Hi,
I tried to engrave some glass and got pretty poor results.
I used the settings on the cheat sheet by the machine (but may have put them in wrong of course).
As you can see I got very wide pitted lines (about 0.5mm) the line width was 0.001 inch.
Has anyone got any tips for settings etc?
or can you see /guess what I’ve done wrong?
Thanks,
Use raster engraving, rather than lines. The “cut” operation dumps too much heat at once into the glass, so you get this extreme spalling. Your design should be a 2-tone image, rather than thin lines. Try 100% power, 100% speed, 300 ppi. Turn down the power if the engraving is still too deep/rough.
Agreed, raster only on glass, not vector, if you do vector go very, very fast and low power and adjust the power up until it marks it.
Thanks guys,
I’ve seen some people on the internet that put a damp paper towel on the glass for a frost effect. Have you tried this?
Opinion is divided. That’s how we were shown to do it by Trotec (they used newspaper) but it seems to work just as well without. Experiment!
I’ve never found it to be that important, but your milage may vary. Whatever the glass is coated in usually makes a much bigger difference.
