Im currently developing an outdoor rug and was wondering if anyone who had a good knowledge of plastics and the laser cutter would be able to help advise me a suitable material to make a fixing clip.
I have done the first test out of a 5mm black acrylic. however I want to reduce the thickness to around 3mm. I also know that acrylic is quite a brital material.
Is there any materials that come to anyone’s mind which would be laser cutter friendly and robust? Nylon / Acetale ?
I don’t see why not. Others might be able to give you precise settings for the Trotec. I’ve only cut it on the laser cutter in the school where I work which is only a 40W machine so the Trotec should cut like a knife through butter!
I looked into an off the shelf version however I couldnt find the exact one to fit the sizing specification. I’ll run some tests on the laser with the Acetal. Thanks for your help again guys, much appreciated!
