So if I was you, I’d try out some small tests with acetate and see what results you get. If it looks weird (lots of smoke or material melting and leaving sticky residue), then stop.
One thing to note though is that we also have a vinyl cutter in the space which might actually work better and more reliably for this kind of material!
Cheers Rob, both would work so I’ll aim for acetate for now.
I’m broadly aware of the vinyl cutter but for these (small) pieces I’m planning to fit the transparent section over another shape I’m cutting from perspex so was hoping to use the same cut shape from my file as the easiest way to get them the same shape.
