Hi would the laser cutter be able to cut a hole in 20mm thick Oak?
I think there is a function like for stepping down in Ruby @Brendon_Hatcher?
Hi Af, it won’t cut more than 12mm due to the focal depth and distance of the surface youre cutting to the bottom of the nozzle. Laser Cutter - Trotec Speedy 300
Check the tool page!
trying to cut down in increments down to 2cm would damage the laser
Af, how about the CNC or a router?
CNC can do it - how big is your piece?
The top surface would also get very charred due to the repeat passes of the laser.
Or laser cut a template and use a router with guide bush
that’s a bomb idea!!! I dunno why I never thought of that!
could you cut the hole with a few passes of the cutter, stop the job, move the bed up, then do a few more passes with the laser? Or would that just completely char and destroy the hole.
