I was having issues with the laser not cutting accurate last night. I put it down to my material being a little wonky, but when I went to clean the lems I noticed (see attached photo) @lasertechs is this an issue?
I checked the machine over and it is well aligned. The lens however is a write off. Someone has managed to actually melt a divot in the edge of it, and a crack has started propagating from there. The central part is still ok, hence the good cutting, but we can’t use a cracked lens. Zinc Selenide is poisonous so we don’t want the crack to turn into a shatter and have to pick tiny shards of poison out of the machine.
**Until a new lens arrives, the cutter is out of order. **
I cleaned the machine as per the induction and I don’t believe I tightened the lens well enough. It moved when I tried to cut again - and I switched the emergency switch above the machine to stop it.
I then sought the guidance of another person who was laser inducted - I can’t recall who. They helped to ensure it was tightened properly, I tested the machine worked by cutting a simple piece, cleaned the area I was working in, and I left for the evening.
Just a thought … maybe only laser techs should clean the lens? I was planning on doing some cutting tomorrow for a Workshop I’m organising. Any idea how long it takes to receive and install a new lens? Thanks!
“Toxicity studies to determine the risks of handling or ingesting ZnSe have show that this material is not toxic. However, long-term effects of ZnSe dust inhalation are unknown.”
I have heard it repeated before on Discourse and at the space that zinc selenide is toxic. I am not sure where this information is coming from, as it would appear to be refuted by the manufacturer.
