Laser cutter cleaning routine
@lasertechs, inspired by this topic and the fact that I’ve been using the laser cutter a lot lately, is there a cleaning routine that I should be following after making a couple of cuts?
I’ve made a habit out of using the air pump to clean the lens, and I sweep the bed after I’m done, but is there more I should be doing after spending an hour with it?
Ensure that the lens and mirror is clean.
@nico.dejong.nz, I’ve made a habit out of cleaning the lens. Is there a guide somewhere to cleaning the mirror?
Pretty much the same procedure as with the lens, except with the mirror (two thumbscrews on the mirror)
