Laser Cutter Challange
I have a quick challenge for the people amongst us who like such things :smile:
I need a very simple holder for our red door tags that is able to be solvent welded to a plastic project box, can hold the tag in a vertical position securely but the tag is still easily removable.
I was thinking a snug pocket where the tag is placed in from the top and will stay there with its own weight until its removed again.
I Think it could be done with two laser cut piece of acrylic but I though it would be good to throw the challenge out there…
What do you think people ?
Courty
I already designed this a year ago. Gimme a sec :smiley:
I really can’t wait to get inducted to the laser!
Just seeing this post makes me want to engrave everything…
This design includes IR emitter/sensor holes to detect tag presence without reading the RFID. Tom L had a particular part in mind, which I had very precise pmeasurements for.
Can re-work to suit 6mm acrylic and remove the sensor holes.
Lol, that’s cheating!
Don’t need the infrared holes, just need to hold the tag flat against the project case.
Courty
Ok, I’ll be in the space tonight so can have a go making one.
