Laser Cut Wooden Moulding Block
Tags: #<Tag:0x00007fa358362380>
Hi Everyone,
I hope you are all well.
I am looking to get this moulding block file, laser cut out of 3.0mm laser plywood. I don’t currently have a membership anymore as I’ve moved from the city and every laser cutting business has charged me far too much to do this.
Is anyone in the space able to do this? I am happy to reimburse for materials, postage, etc.
I leave attached the file.
Cheers,
Louis.
3LMoldingBlock.pdf (1.3 MB)
The item you want made is on the large side of making with a laser cutter, If none other offer to help let me know and I can try to do it I think on my Glowforge pro.
That’s very kind of you Dorine. Would the trotec you have last I remember not be large enough? If not then I’d like to take you up on the offer using the Glowforge. Like I say, I’d be happy to reimburse you for the material, postage, etc.
Cheers,
Louis
The Trotec would be big enough for sure, I’ve not done an induction on it yet so cant use it. What you might like to consider is rejoining the space and coming to laser it yourself :slight_smile:
