I made a couple of Klask style games as presents.
I designed them in Fusion360 and laid them out using the Mapboard Pro plugin (recommended).
I then cut them out of 12mm Ply on the big CNC. A Downcut bit to cut through the first 3 mm and then an upcut bit for the rest.
A few dominos and glue to construct them and then I used the vinyl cutter for the blue and white areas on the playing board.
I’m currently 3D printing the playing pieces, putting a pause in at the appropriate point so I can drop the magnets into place.
