I have a Denon hi-fi from Japan that was my brother’s and he used it when he lived over there. I want to be able to give it to another family member and have it work. I have a step-down transformer that halves the British 240V output down to 120V to use American appliances. However, over in Japan they have a funny mix of voltages depending on which part of the country you are in. This particular hi-fi specifies that it is for 100V. Would I be safe to use my step-down transformer with output at 120V in this hi-fi, or is it likely to blow up?
Someone else may have a better answer, but usually mains power is considered to have a 10% tolerance…
230V +10% = 253V
230V -10% = 207V
This is why across Europe the voltages vary due to legacy systems:
UK: 240V
Italy, Spain & Russia: 220V
Everywhere else: 230V
With a 10% threshold at 230V every country is included.
However in Japan using a 120V transformer for a 100V product (+10% = 110V) would be significantly out of tolerance, you could measure the real world voltage of the transformer to confirm it’s actual output, but personally I would suggest the answer is no.
However it’s unlikely to go bang, so much as run too hot and wear out prematurely.
In 1960, the supply voltage to domestic properties in the UK was nominally 240 V AC at 50 Hz, although the declared voltage in the UK is now 230V AC +10% to -6% done I believe at the same time the colours were harmonised
. … Since 1995 the nominal voltage across Europe has been 230V (400V 3 phase).
In practice nothing has been changed in the UK.
This was my understanding and has been confirmed online so @unknowndomain you are correct
Until recently I was a National Inspection Council for Electrical Installation and Contracting (NICEIC) registered electrician
I expect @andrew_d you will be fine
Wait for it…
I am a fully trained in portable appliance testing. Lol
This is where I learnt this.
My own outlet supply voltage is currently 242V. It has been fairly consistent when I have tested it over the years. I will do a test with the transformer later on.
