Does anyone know a solution to broken lines in inkscape. when I draw an object > save > re-open all my solid lines have been broken into millions of nodes with visible breaks. Any idea how to solve this?
no I’m not using the space pc. if you zoom in you should see loads of breaks in the lines. I draw it and it’s all solid Save and open and all lines broken, I don’t get it?
That’ll be your issue. DXF doesn’t support smooth splines very well. Inkscape is breaking your curves into hundreds of tiny lines because that’s the only way it can save them.
Stick to SVG for working and export to DXF for whatever machine you’re using that needs it.
