afshind
(Afshin Dehkordi)
1
I have to hang a clothes rail, its a narrow span 30-40cm…both walls are plasterboard…the tricky bit is one wall is sloping at approx 45degrees.
How should I do it? Cut two 2x4in brackets and sit the rail in a groove on top?
I have plasterboard rawl plugs, its the sloping wall that is troubling me.
RichM
(Rich Maynard)
2
Not sure I completely understand the description, but I if I do I’d make a 45 degree wooden block so you’re fixing the rail to something vertical.
afshind
(Afshin Dehkordi)
3
Understood perfectly! : )
And will be generous with the rawl plugs
