Help with small project
Hi Everyone,
I have recently re-subscribed after taking some timeout, I have a lot of idea’s and can’t wait to re-engage with the community.
I have a small project which I would like some help with. I have a left-over piece of wood bench-top leftover from a kitchen renovation, it measures: 43cm x 30cm x 4cm. I would like to turn it into two chopping boards by cutting them in half so they would both be 2cm thick, I then would like use the large planer to make sure they are flat before sanding the edges.
I would appreciate any help regarding using the bandsaw and planer. I did complete the woodwork induction last year, but I need to complete the assessment for these tools. Hence, if someone can do the cutting / planning, that would be greatly appreciated.
I am quite flexible with my time, so please reach out if you can help :slight_smile:
Thank you!
Hello,
I can help you with the assessments if you want, does Sunday work?
Hi Paul,
That would be great, thank you.
Yes, Sunday works for me, what time works best for you?
Thanks.
Let’s say 11am?
Perfect, see you then.
Hey Paul,
Hope you are well. Just a quick one. I’m at the makers space today and I don’t seem to have access to the bandsaw. Who can I reach out to so I can get my fob activated?
Cheers,
P
Can you clarify whether you need the induction, or if you have had the induction and your fob hasn’t been activated?
Hi Brendon,
It’s the latter, I had the induction with Paul L in Feb, just need my fob activated.
Thanks,
P
@plietar can you nudge admin to get the fob activated?
Thanks to both of you :grin:
Ah I’m so sorry i think I forgot to put in a request after your induction. I have done so now, you should get access very soon.
I hope you were able to work around this today.
All good, managed to get access.
Thanks again :+1:t2:
