Help with laser
Hi everyone is there has someone help me laser .i have design six box for my art program
Like this 6boxes like cupboard
You can put the dimensions in here
It will give you an svg file you can put into the laser.
Can also use MakerCase - Easy Laser Cut Case Design
if those bottom ones are shelves.
Once you have the file, you can open it up in inkscape and add images to be engraved or make modifations.
Although I think they are approacing the size of what’s available in the shop.
You might consider using tracksaw or CNC to do these. Laser ply is much more expensive than regular ply.
