Is ChatGPT’s info any use? If not, maybe be more specific on what info you want.
In the UK, 802.11ah (Wi-Fi HaLow) operates in the 863 MHz to 868 MHz band, which is regulated by Ofcom and falls under the ETSI (European Telecommunications Standards Institute) standards. Here’s a breakdown of how individual channel frequencies are defined:
802.11ah Frequency Allocation in the UK
• Frequency Band: 863 MHz to 868 MHz
• Channel Bandwidths: 1 MHz, 2 MHz, 4 MHz, 8 MHz, and 16 MHz
• Number of Channels: Up to 5 channels for a 1 MHz bandwidth
Individual Channel Frequencies (1 MHz Bandwidth)
Channels are spaced 1 MHz apart within the 5 MHz available:
Channel Number Center Frequency (MHz)
Channel 1 863.5
Channel 2 864.5
Channel 3 865.5
Channel 4 866.5
Channel 5 867.5
Wider Bandwidth Configurations
For larger bandwidths, fewer channels are available:
- 2 MHz Bandwidth:
• Center frequencies: 864 MHz, 866 MHz
• Only two channels fit within the band.
- 4 MHz Bandwidth:
• Center frequency: 865 MHz
• Only one channel fits within the 863–868 MHz range.
- 8 MHz and 16 MHz Bandwidths:
• These configurations are typically unavailable in the UK due to the limited spectrum range.
Regulatory Restrictions
• Power Limits: UK regulations enforce a 25 mW EIRP (Effective Isotropic Radiated Power) limit in the 863–868 MHz band for short-range devices like 802.11ah.
• Usage: This band is primarily for low-power, wide-area networks (LPWAN) and IoT applications, making it ideal for Wi-Fi HaLow’s use cases (e.g., long-range, low-power connections).
For exact implementation and device compatibility, manufacturers must ensure their equipment complies with ETSI EN 300 220 and Ofcom’s regulatory framework for sub-1 GHz communication.
