I’m currently using an EE Mifi device for Internet access in my house in Hertfordshire.
I’m slowly adding more ESP8266 based IoT devices.
My problem is that the mifi device will only allow 10 connections,and I’m soon going to be at that maximum.
It doesn’t have any wired connection, so I can’t add a simple Wireless access point.
What I’m looking for is something that will connect wirelessly to it, and then provide a second wireless network with a different SSID that I can use just for IoT devices. It would be a bonus if it also provided a wired Ethernet connection as well.
So what am I looking for? I don’t even know what it might be called…
If you do this it will be slow, but you could buy a USB 4G dongle and plug that into a router with USB support…
Otherwise any wireless router, that doesn’t have a built-in cable or ADSL model should support this, in fact there is one that belongs to the space you can loan for now?
Technicolour something or other. It has a USB port for the stated purpose too.
So I could use a router in bridge mode to give me a wired connection. And then I’d need to connect another access point to that to give me a 2nd wireless network…? Was hoping for a one box solution. But I already have lots of spare routers kicking about so maybe that’s the answer.
