As per discussion on safety, the heat press has been taken out of action until we are able to correct the voltage situation which has been caused by a previous repair which makes it a fire hazard.
@dorine is working on correcting this.asap.
@Nancy I have a small heat press at home (about 30*30CM) if you want me to lend it while the big one is out of comission
That would be really helpful, are you local?
Yea, I will bring it round about 5PM
Do you need some electronics help?
Although I posted this so everyone was in the loop and no one came down to use something broken.
Dorine and Joe are actually on the fixing plan. So I’m sure they appreciate the offer but I leave them to discuss with you what’s needed.
Nancy
Thanks @Destom do you need help like a car to get it there?
@emuboy the heat press has a number of issue @joeatkin2 is going to put a parts list together for its repair and in the mean time we will use @destom press while we sort out what needs doing to it
Are we able to keep it somewhere out of the way while it’s out of commission? It’s pretty big
I’m nearly better, waiting to get 2 clear Covid tests before I come back to the space to deal with the clam heat press. @joeatkin2 any further thoughts on the parts list we need to get it back working?
