Hi @lasertechs
When using the laser cutter above 60% speed today I noticed that it began to judder and then halted, displaying the following error: Hardware error E2000_147 occurred: Tracking error on y-Axis. All the lights flashed on the control panel and there was a beep. After switching off and on again the error cleared but the fault persisted when trying to cut at higher speeds.
It was fine at slower speeds (5%). I didn’t try speeds higher than 5% so I don’t know where the speed threshold is for the problem (and sadly, I didn’t have time today to experiment).
I googled the error but couldn’t find much. One person suggested it may be a sensor issue but I don’t really want to mess around with something I don’t understand very well.
Sorry to be the bearer of bad news!
Glenn
