I built this antenna from a kit a while back, using a 90W soldering iron. It’s meant to be soldered with a torch, and unfortunately the solder joints weren’t great. Is there a torch at the Makerspace I can use, along with flux and solder? It’s basically copper plumbing tube and brass plates.
@lewisss Thanks, that would be amazing! When are you usually at the Makerspace? I’m planning to do some laser cutting this weekend and next weekend. Are you around then?
I’ve got a standalone SDR and a usb one, never really used them.
My latest toy is a frequency analyser combined with a directional antenna for finding sources of interference. There’s sometimes problems, I run LoRa networks at music festivals to monitor the wind (and now lightning).
