Does anyone have glass cutting equipment i could borrow please?
A neighbour is throwing out vintage single pane bathroom sash windows and I wanted to cut the frosted glass out to use for another project.
Can post a pic Tuesday
I have a glass cutter. I can bring it on Saturday. Not always easy to do a cut out but I can try and help! Might be easier to deglaze the sash first
You have to take out putty out of the windows and take the glass out then cut it , and old glass can be a pain cut, but if I a about I will be happy to help
Thanks @joeatkin2 @Jackd …I’ll bring windows down saturday…they are not full size sashes, small ones.
I suspect cutting the glass will leave razor sharp edges…should I buy some special sandpaper to use to leave smooth/rounded edges?
If you want to clean the edge
It’s old glass it might just make broken glass.
You will need 3 in 1 oil as well
And a glass cutting tool
I have a glass cutter, will look tonight if I have the oil for it but like Joe said 3 in 1 is just as good. I thought I saw some by the wood lathe?
There should not be any in the workshop!
