I would go straight for the pro version of mapboards currently it si 25 usd, there is a 9.99 version too
https://apps.autodesk.com/FUSION/en/Detail/Index?id=3399489440307590024&os=Win64&appLang=en
I’ve been using https://apps.autodesk.com/FUSION/en/Detail/Index?id=7634902334100976871&appLang=en&os=Win64 quite successfully - although also using illustrator to fix and tweak the line weights before cutting.
I used that in the beginning its not bad or you can use the native export but the change over is well worth it especially if you have drawings with multiple sketches and or parts
Mapboards comes into its own when you have a model made up of many parts
Fusion now natively can export to DXF, FBX, OBJ, STL, SPD, and SketchUp (SKP) Files right from the Fusion 360 file menu.
May 20, 2019 Product Update – V.2.0.5790
