So the extraction system is all joined up again post truck incident. With the new flow controller and condensation barrier added. The flow control is stuck in the SHUT position. So please do NOT use the extraction system.
I don’t suppose you noticed if the LED was on on the RFID reader board? It occurs to me that a wire could easily have been dislodged if you were working on the ventilation beside it.
So I closed the shutter. Though to put a sign on the extraction control box. Opened the shitter. Went to operate the door sensor. No luck. Closed shutter again.
Yes I may have dislodged something
