Hello @lasertechs and all, the laser focusing tool has gone missing. I remember this happened before and it was down a hole? Anyway - mainly to let you know…
@techfolderkites did you have the tool when you were here? Any ideas?
I used it Sunday and was defently there.
do you mean the metal piece that you hang off the laser to get the right depth? if so a couple of weeks ago someone had accidentally put it into the scrap bin next to the laser cutter, might be worth checking in there
Yes thats the one! Oh no!
We poked around in there a bit, but may need to do a more thorough search!
yeah I found it on a second pass - emptied it out and it was right at the bottom. Worth checking the other bins nearby too?
We should really build a replacment before we throw it away.
Has it been found? @lasertechs might need to order/make a new one? Happy to assist.
Just a wild guess, but didn’t somebody recently use the laser who hasn’t been around a lot and asking where the honeycomb was located? I vaguely remember from last Open Evening that the honeycomb was lying on the bench next to the metal-lathe. Is it possible, that somebody forgot to put the tool+honeycomb back into the laser??
Not sure if I’m misunderstanding you but I’m not suggesting anyone put it in the bin deliberately…
So, to summarise…
It went missing a while ago.
Nick found it in the bin and put it back.
Now it has gone missing again.
And has not been found.
However, I believe someone has access to the Tool Control access logs, so we could send a message to all the recent users until we find both the last person who had it, and the person who lost it!
I’ll go and have a look for this reason. Will dm you.
Oh we can order another one! Silly me thinking we weren’t able to do so!
Also, in other news, I think the X axis (?) is on its way out was doing a dragging noise the other day while moving quickly between 2 points
sometimes it speeds up, but was it a repetative skip that looked unusual?
we might have to just make one, it seems like waste of money now that people throwing it in the bin. 35£ for a stick with a lip. ah. It needs to be accurate, but i have a way!
Id put it out of order if you say theres something wrong with x-axis just in case so it doesnt chew up the belt whatever it is
didn’t skip,only a dragging noise, maybe the rail just need some oiling…
No oiling!
ok, I officially have no idea what I’m talking about.
Good observation though!
I’m sure there’s a spare one. I’m very careful and sure I put it back on Sunday.
