lewisss
(Mark Johnson)
12 September 2023 13:04
1
I have done a complete fault finding on the fire alarm system.
One of the sounder bases has water damage, see pictures.
Can @directors order a replacement asap please.
The fault will remain on the control panel until this is replaced, however the working of the fire alarm is not compromised as it is a loop system that is fed from both sides.
https://www.firedetectionshop.co.uk/p/apollo-45681-330apo-xp95-addressable-sounder-beacon-base/
Also does anyone know where the laptops are that were in the space. As one of them was used for programming the system
lewisss
(Mark Johnson)
12 September 2023 13:23
2
Hold on the ordering of this, let me bench test the faulty unit first
Sean
(Sean McCarthy)
12 September 2023 13:24
3
The laptops are in a box in the snug - I believe it’s a clear plastic box on the bottom shelf of the shelves
asander1
(Andy Sanderson)
12 September 2023 13:35
4
Thanks @lewisss !
Let me know… Not sure if it is related, but there is a leak that has been there since January:
https://discourse.southlondonmakerspace.org/t/leak-in-arch2/25353
Still not fixed as far as I know…
lewisss
(Mark Johnson)
12 September 2023 13:44
5
This is at the front above the table saw, there was a leak here but that has now been fixed
lewisss
(Mark Johnson)
12 September 2023 13:49
6
Tested the unit and it is faulty can you order one @asander1 , and let me know when it is in and I can recommission the system.
As I said, the system will be operational and working (but only one direction as opposed to bidirectional as it should be)
The fault will still show on the control panel
Ryanf
(Ryan)
12 September 2023 13:54
7
Should we order more than 1 incase something like this happens again? Then we won’t need to wait for a replacement before fixing it.
lewisss
(Mark Johnson)
12 September 2023 15:20
8
I don’t think that is necessary, as next time it could be a detector.
Water damage caused the issue and that was fixed in that area, so very unlikely that it will happen again.
lewisss
(Mark Johnson)
13 September 2023 21:28
11
My fault, I forgot to put those back on!
All four call points may be off, if someone can go round and check they just push on and lift up to lock them in place.
Only 24v dc on the cables so no danger. Back in tomorrow
dannz
(Dan Law)
13 September 2023 21:49
12
I’m still here and can do that - or at least give it a go. Didn’t want to do anything not knowing what should be done.
dannz
(Dan Law)
13 September 2023 21:56
13
All four located and face plates fixed back in place.
PReardon
(Paul Reardon)
14 September 2023 08:26
15
We currently have a “Loop integrity Fault on Loop 1”
With a flashing General fault light flashing.
I know the fire alarm works as some smouldering set it off a few minutes ago
Destom
(Destom)
14 September 2023 10:27
16
I think that is the fault Mark ordered the part to fix.
lewisss
(Mark Johnson)
14 September 2023 11:24
17
It is , @asander1 has ordered it, hopefully it is in by tomorrow so I can fit and commission.
asander1
(Andy Sanderson)
14 September 2023 12:36
18
Came today! Will leave with your name on it in the mail inbox by social area…
lewisss
(Mark Johnson)
14 September 2023 15:16
19
Will be in about 1pm tomorrow to install
PReardon
(Paul Reardon)
14 September 2023 19:46
20
I should be around about 2ish if you would like a hand
