Joining machine DOMINO DF 500 Q-Set 230V
Technical Data
| Power consumption | 420 W |
| Idle engine speed | 25 500 min⁻¹ |
| Depth stop for routing depth | 12, 15, 20, 25, 28 mm |
| Max. routing depth | 28.00 mm |
| DOMINO slot cutter dia. | 4, 5, 6, 8, 10 mm |
| Routing height adjustment | 5 - 30 mm |
| Mitre routing | 0 - 90 ° |
| Dust extraction connection diameter | 27 mm |
| Cable length | 4.00 m |
| Product weight | 3.20 kg |
| Drive type | Mains |
Noise and Vibration Levels
| Routing: Uncertainty (vibration) K | 1.50 m/s² |
| Routing: Uncertainty (noise) K | 3.00 dB |
| Routing: Total vibration average, Ah | 3.00 m/s² |
| Routing: Standards series EN | 60745-2-19 |
| Routing: A-weighted sound pressure level, LpA | 84.00 dB(A) |
| Routing: A-weighted sound power level, LWA | 95.00 dB(A) |
Condition Notes
New
Induction and Training
Maintainers
Risk Assessment
Identify risks
State control measures
Before Use
During Use
After Use
Maintenance
References
This is an excellent reference and quick stats guide, read it. There’s should be a copy in the shop as well:
Domino_DF_500_Supplemental.pdf (2.9 MB)
