I have a ESP12F DEVKIT V3 that I seem to have blown a small (very) component on it and need to replace it. Now I know its a cheap dev board, but I would like to repair it for my own satisfaction. Does anyone know what the component part no is? Thanks guys & gals. .
It’s a diode… I would be surprised if it’s that that’s blown. Check the big regulator in the foreground too
Courty
its defiantly that as its all black and burnt but you could also be correct and I will also replace the regulator. Any ideas on the burnt part no? Thanks for the reply.
Dave
Is just a bog standard smd diode, you should be able to get that from any good electronics shop.
Thanks for that I will give it a try
