Hey I’ve been using the laser today as normal everything’s going smoothly now I’m seeing a hardware error, and all the laser cutter buttons are flashing? Not sure how to fix, if someone can help that would be great!
Hi @sydneyrobson did this get resolved? I’ve booked to use the laser after you this evening and just want to make sure it’s not a wasted trip!
Cheers
If it is still not working, you can call me. I’ve sent you a private message with my number.
Thanks Brendon!
Hey sorry it’s all fine now!! Was just a momentary issue then it was resolved sorry to cause panic!!
Was it limit switch triggered?
I think this happened when I was using it - I moved the laser head all the way over to the right-hand side, and it gave me that error.
I just turned the laser on and off and it resolved itself.. Was that the right thing to do?
Yes, although usually you have to physically move the head off of the limit switches - when the machine is powered off.
