I’m having problems sending jobs to the laser this morning. In Ruby the “Push to Laser” button is disabled and greyed-out in the top-right of the “Prepare” screen. The “Queue” button is not disabled, if I click it an error pops up saying “ERR_DEVCOM_011”, which doesn’t yield any results from Google.
So far to troubleshoot I have:
- Restarted the laser and PC multiple times, restarted the tool control node (by powering off the PC)
- Ensured the lid is down and the laser does the little jiggle warm-up after being powered on
- Made sure that the honeycomb bed is correctly sat on the locating tracks
- Opened / closed the side of the unit to confirm that it is not ajar
- Manually moved the laser head with the direction arrows, also raised / lowered the bed
What do you suggest I do next?
Edit: Updated title in the hope that it’ll be easier for others facing the same problem to find this page from Google once it’s indexed
