Kitchen has been replastered. Plan was to leave the plaster finish, just sealing it. On a really tight schedule…But…
Something has leeched out!?
Any ideas what’s gone wrong?
Have they overlooked something in preparing the wall before plaster went up? they just took the old tiles and wallpaper off.
That sloping roof if the part of a chimney breast, they said you could see daylight from there, they’ve sealed it so it does’nt let rain down anymore. But should they have waited for the wall to fully dry? Testing it with a meter? Or sealed it to be sure?
Whats the solution? Will it come through a coat of emulsion paint?
Is exactly what I was thinking, I have seen it in old bathrooms… if that is the case it will show after painting
On very small patches I solved the problem with one or 2 coats of oil based paint (satin wood) but I don’t see it suitable for so large areas…
Absolutely what Mark says — and you must make sure the source of water is stopped. Although the stain coming through now isn’t necessarily a sign that there’s still water ingress.
