Microchips
This is a list of microchips I have found in the space, with links to their datasheets (both online and on the local storage) and the quantity.
Op Amps
- 741CN - Single Op Amp - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM741.PDF
- OPA2604 - Dual FET-Input, Low Distortion OPERATIONAL AMPLIFIER - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/OPA2604.PDF
- LM324N - Low power quad op amps - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM124.PDF
- LM358N - Low power dual operational amplifiers - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM158.PDF
- LM386N - Low Voltage Audio Power Amplifier - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM386D.PDF
- NE5532P - DUAL LOW-NOISE OPERATIONAL AMPLIFIERS - x4 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/NE5532.PDF
- OPA2134PA - High Performance AUDIO OPERATIONAL AMPLIFIERS TM - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/OPA134.PDF
- TL052CP - ENHANCED-JFET LOW-OFFSET OPERATIONAL AMPLIFIERS - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/TL05X.PDF
- LM324 - Quadruple Operational Amplifiers - x40 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM124.PDF
Filters
- 24C02 - Schmitt Trigger, Filtered Inputs for Noise Suppression - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/AT24C08A.PDF
- 24C04 - Schmitt Trigger, Filtered Inputs for Noise Suppression - x8 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/AT24C08A.PDF
Audio
- PT7313E - Stereo Audio Processor for Car Audio - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/PT7313E.PDF
- PT2399 - Echo Processor IC - x14 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/PT2399.PDF
Comparators
- LM393P - DUAL DIFFERENTIAL COMPARATORS - x5 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/LM193.PDF
- MAX931 - Ultra Low-Power, Low-Cost Comparators with 2eference - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX931.PDF
Converters
- A75451b - DC-DC CONVERTER/BOOST (STEP-UP) LOW-NOISE 4.5A STEP-UP CURRENT MODE PWM CONVERTER - x10 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/A7545.PDF
- MAX138CPL - 3쩍Digit A/D Converters with Bandgap Refrence and Charge-Pump Voltage Converter - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX138.PDF
- MAX140CPL - 3쩍Digit A/D Converters with Bandgap Refrence and Charge-Pump Voltage Converter - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX138.PDF
Current Controllers
- UC3842AN - High Performance Current Mode Controllers - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/UC3842A-D.PDF
- UC3843AN - High Performance Current Mode Controllers - x3 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/UC3842A-D.PDF
- UC3845AN - HIGH PERFORMANCE CURRENT MODE PWM CONTROLLER - x7 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/UC3842A-D.PDF
Drivers
- MAX445 - Low-Cost, High-Resolution, 200MHz Video CRT Driver - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX445.PDF
- MAX233CPP - 5V-Powered, Multichannel RS-232 Drivers/Receivers - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX220.PDF
- L293NE - QUADRUPLE HALF-H DRIVER - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/L293.PDF
EEPROM
- 24C08N - 8K/16K 5.0V I 2 C O Serial EEPROMs - x8 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/24C08B.PDF
- 24C16N - something eepromy - x9 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/.PDF
- 24C32 - 32K 5.0V I2C Smart Serial EEPROM - x8 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/24C32.PDF
- 24C64 - 2-Wire Serial EEPROM - x6 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/AT24C32.PDF
Logic Gates
- GD74LS02 - QUADRUPLE 2-INPUT POSITIVE-NOR GATES - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/GD54LS02.PDF
- HD74LS00P - Quadruple 2-Input NAND Gates - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/HD74LS00.PDF
- HD74LS08P - Quadruple 2-Input Positive AND Gates - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/HD74LS08.PDF
- DM74ALS00AM - Quad 2-Input NAND Gate - x50 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/DM74ALS00A.PDF
Microcontroller
- Mega328P (MEGA32C1-15AZ) - 8-bit Microcontroller with 16K/32K/64K Bytes In-System Programmable Flash - x10 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/ATMEGA16M1.PDF
Misc
- MAX712CPE - NiCd/NiMH Battery Fast-Charge Controllers - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MAX712.PDF
- MCP23017-E/SP - 16-Bit I/O Expander with Serial Interface - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/MCP23017.PDF
- NE602AN - DOUBLE BALANCED MIXER AND OSCILLATOR - x3 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/NE602A.PDF
- CD4013BCN - Dual D-Type Flip-Flop - x2 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/CD4013BC.PDF
- TISP4080M3BJ - BIDIRECTIONAL THYRISTOR OVERVOLTAGE PROTECTORS - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/TISP4070M3BJ.PDF
- ULN2803A - Eight Darlington array - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/ULN2801A.PDF
- CD4051BM - CMOS Analog Multiplexers/Demultiplexers with Logic Level Conversion - x3 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/CD4051B.PDF
- DS3231SN - Extremely Accurate I2C-Integrated RTC/TXO/Crystal - x5 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/DS3231.PDF
Shift Registers
- CD4021BE - CMOS 8-Stage Static Shift Registers - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/CD4021B.PDF
- SN74HC595N - 8-BIT SHIFT REGISTERS WITH 3-STATE OUTPUT REGISTERS - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/SN54HC595.PDF
- 74HC595N - 8-bit serial-in/serial or parallel-out shift register with output latches; 3-state - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/74HC595.PDF
- 74HC595D - 8-bit serial-in, serial or parallel-out shift register with output latches; 3-state - x80 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/74HC595D.118.PDF
Timers/Counters
- NE555p - precision timers - x13 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/NA555.PDF
- TC4017BP - DECADE COUNTER/DIVIDER - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/TC4017BP.PDF
Transceivers
- SN75176BP - DIFFERENTIAL BUS TRANSCEIVERS - x1 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/SN65176B.PDF
- LVC16T245 (74LVC16T245DGGRE4) - 16-BIT DUAL-SUPPLY BUS TRANSCEIVER WITH CONFIGURABLE VOLTAGE TRANSLATION AND 3-STATE OUTPUTS - x10 - weblink - file://10.0.4.25/Share/Users/ElectroTechs/Components/SN74LVC16T245.PDF
