Sam from Bandgap came to visit a few weeks back with some samples of Lumilor electroluminescent (EL) paint – the samples are stored on right hand side of the high shelf of the 3d Print station if any members want to have a look – but put them back of course!
In brief: it’s a mutilayer paint system that creates a light-emitting capacitor using PN junctons…light is released when highish frequency alternating current is applied across it…
Or…it’s magic paint that lights up when you flick a switch.
This has taken off in the high end car body spraying world — and the odd airbus…
and Brompton bicycle — but Sam is keen to see how it can fit into the Makerspace world: there’s a lot of Tron-like stuff being done with it, but it has many possibilities. This is not a cheap product, but read on to see Sam’s offer to supply more affordable ‘project sized’ quantities than are normally available.
We’ve had a few email exchanges which has resulted in the following offer to Makerspace members.
Okay, I’ve done a lot of thinking on this and have bounced ideas around with my business partner as well.
I came up with the following:
We offer a workshop at a total cost of £40 + VAT (total £48 per person), for a minimum of 10 people - otherwise we’ll have to rethink costs) which includes:
£17.50+VAT for material to light up 100cm2. This includes lacquers, top coats, and consumables.
£22.50+VAT for all our costs and time.
Ideally, we would have enough people interested in it at this extremely cheap price (normally people get charged thousands of pounds to be trained as an applicator by either LumiLor or other applicators).
During these workshops people will light up an acrylic plate, with rounded corners (I’ll need to get these cut on the laser cutter), then block out any design of their choosing using vinyl.
This pretty much guarantees that everyone will get something which lights up at the end of the evening. Possibly the top coating will need to be done in another session.
They would lacquer over the top of the block out paint, and if they want to, can sand that down with an air powered orbital sander (DA) then lacquer again to get a perfectly smooth finish with no
raised/embossed sections, in either gloss, matte or satin finish.
Then, once people have done this workshop and have lit something up for the first time (and got the excitement from that), we could do sessions where people do more complex projects. We could then agree on a rate for this and will also be able to supply all of the other paints needed. We have the facility to powdercoat metal items (and remove old paint or powdercoat), so anyone wanting to do their bike for example will be able to do it properly.
After this initial training session, the cost of LumiLor will be £15.50 + VAT per 100cm2 area. An A4 piece of paper which is a very large area (you could do 10 small logos, 2+ bikes, pin strips etc. with this amount of material), would cost £93 + VAT at this rate.
If all this is a success, we can do workshops for applying LumiLor with an airbrush as well which is a little more difficult but uses a tiny amount of material so will be very cheap for people who get good at it.
Anyone interested in attending a workshop on this unusual and highly adaptable material please indicate in a reply below.
Any questions? Put them below too: Sam will likely join Discourse and be able to answer – and he’s keen to become a member too, when he gets a bot more time.
https://drive.google.com/a/bandgap.co.uk/file/d/1BkmqRyAlBNYOnIsEjvvAlyktMb3fe_Bt/view?usp=drive_web
https://drive.google.com/a/bandgap.co.uk/file/d/1-EFTLkavdwzF1JiezaUie8SAtvBYnup3/view?usp=drive_web
