Sketching
New! Control Point Frame in Insert SVG
Now when you insert a SVG as a sketch into Fusion 360, the Insert SVG dialog now contains an option for you to turn on/off Control Point Frame, so you can edit those SVG edges as control point splines.
Pro-tip – if you’ve inserted a SVG with this option turned on, you’ll see green control points all over your SVG sketch. To make them editable, window select the whole sketch, right-click and pick “unfix”. This will unfix the points so that they become editable.
