Easiest way to control a NEMA 17 stepper motor
I need to control a NEMA 17 stepper motor (I’ve got a NEMA 17 Stepper Motor Model 17HS16-2004S).
I looked online quickly and decided to buy a ‘Easy Driver v4.4’ but now I’m wondering if that will actually work. It seems that that driver only works with max 750mA stepper motors, and I think that the NEMA 17 motor I have is 2A.
Also, I’m confused about voltage. From tutorials I’ve found it says I should supply 12v to the driver board, but the stepper motor seems to be 2.2v? I’m I right in thinking the board will use the correct voltage for the stepper.
I would like to control this by either a Raspberry Pi or Arduino. I only got the Easy Driver because it was cheap, I don’t have to use it.
Please could anyone point me in the right direction.
Thanks!
Hi Stuart,
The 12V is wired to Power in (6-30V) - +, this will power the stepper motor. The GND and +5V can be wired straight from your Arduino GND and 5V pins. This will power the stepper motor driver (black chip and circuitry).
Hope that makes sense.
Good luck!
Daniel
Thanks Daniel! I got it working :smiley:
