"E505WMT warm white led screw bulb base e5 e5.5 12v -14v"
Hello, I’m looking for some small, I think the size is called E5, screw in bulbs and the ‘screw in’ part as well. But already wired up. I don’t know if the bulb comes with the screw in part as well it probably does. That’s probably a silly question. Anyway here’s a photo:
I can’t find any on Amazon, I think I’ve seen some in the 4D Model Shop but they’d be cheaper on Amazon and I think it would be the same quality. I need them pre-wired like in the photo.
Any ideas where I can get a bunch of them? Thanks!! :star:
US $3.52 28%OFF | 10 Pcs 12V 10mm Pre-Wired Constant LED Ultra Bright Water Clear Bulb Cable Prewired Led Lamp CLH@8
I had a look at AliExpress, is this it?
Yes, I need them next week but if I can’t find any these look good. Thanks Petra👍🏾
Pre-Wired Diffused LED Diodes Light DC 9-12V 3 5 10mm Water Clear White Red Blue Green Light 50Pcs(Rosso-5mm) https://www.amazon.co.uk/dp/B07NPKCB5H/ref=cm_sw_r_apan_glt_i_69GVXNBW695ZE57NGYK6?_encoding=UTF8&psc=1
Oh, that’re not the threaded ones …
Yes I need the screw in ones :+1:t5::wave:t5:
either of those?
Here they are!! Thanks Julia :+1:t5:
