I’m currently attempting to fix up a DUAL CS 505-1 turntable for a friend. It’s been sitting unused for 20 years and R1 on the switch-plate smokes after a few seconds when turned on. I’ve posted to a specialist forum on this (https://www.vinylengine.com/turntable_forum/viewtopic.php?f=18&t=124139&p=1119965#p1119965) and I’m making some progress but just thought I would run it by here in case anyone with experience/knowledge of these things is able to input.
I have a 505 too, although I don’t know if it’s the first generation. As we just moved house, it’s about to emerge after 20 years in the loft, and I was thinking of resurrecting it.
Hence - following this topic to see how you get on!
These are Y and X capacitors, Rifa are notorious to be very bad, especially in old equipment, some of this are just filtering caps across the main voltage, jus replace them with equivalent ones
I will contact Mouser as they stock the ones I need and sell them individually and without handling charge. They delivery charge is quite steep but I am hoping that I might be able to get around that by picking up in person when passing one day in the not too distant future.
