Drum Sander
Tags: #<Tag:0x00007fa49ea15ac8>
Hi, will anyone with Drum Sander access be in this evening? I was hoping to use it for a couple of chopping boards I have glued up.
I believe that it is out of commission at the moment. The issue is setting the right tension to keep the feed bed from wandering off from centre. I dont know when this issue will be resolved.
Ah, thanks for the update Darren. Do you know whether there is any issue with me running it through the thicknesser? I don’t know whether glued boards are allowed (all grains are still aligned).
Can’t plane end grain but if it’s not end grain then it’s fine
If it’s endgrain you can face it on the big cnc
@joeatkin2 was going to look at this, but it does look like the belt is stretched past its adjustment which means we will need to look at a repalcement
