Donkey saw
So what is the conclusion?
No on the mechanical hacksaw due to storage?
No on replacing current saw with evolution blade due to rpms?
Keep cutting by hand?
Buy abrasive disc for current saw?
Others?
Silkscreen side of metal bench, nearest wall.
Confused, I was confirming that cupboard in metal bench on silkscreen side did in fact contain some sort of chopsaw. I take the metal topped bench to be part of the @metaltechs empire, not silkscreen!
Oh sorry miss understood, I thought you meant the bench with 3D printers.
The metal chop saw is indeed on the silkscreen Side Of our work bench.
If we buy a new abrasive disc for the current metal chop saw can we use it out the front, due to the fact that using it inside will produce messy dust.
Or do we get one of those evolution saws? They’re not expensive.
Or again do we not use mechanical tools and cut by hand? And drop this thread?
If I remember correctly, there’s a speed controller on the existing metal chop saw, but I might be wrong. If so, might be worth learning what the RPM required for the evolution blades, and whether the existing saw is compatible.
