https://vector3d.co.uk/product/vlmp-threaded-insert-heat-press-stls-digital/
Do we have a heated press to insert brass screw nuts into 3D printed parts as a press that holds a soldering iron?
I don’t believe I’ve seen something like that in the space
I’ve seen people push these in using a soldering iron, not sure if to encourage using a soldering iron in this way but I can’t see how it’s any more dangerous than handling a soldering iron in general.
That how I pushed the ones in the photo in but its fiddly and prone to go in at an odd angle. The press pushes it evenly down at a right angle so when you screw it into the nut it aligns perfectly
I’ve got some tips for a soldering iron that makes it much much less fiddly - https://cnckitchen.store/products/kopie-von-ts100-101-adapter-tips-set-m2-x-m3-m4-m5-m6-1-4-m8-lead-and-cadmium-free
With a bit of practice you can easily get straight results by hand. I’ve got a whole 3d printed 3d printer assembled this way. There were a few places where the screw felt a bit tighter than it should have; and one or two where I had to get the soldering iron back out to adjust the threaded insert.
I found it pretty forgiving as someone still learning. As long as you’ve got enough walls and don’t push it in too far you can fix it.
Hackaday have quite a few detailed articles on this subject however I have never actually done this myself so I can’t say for sure.
https://hackaday.com/2019/02/28/threading-3d-printed-parts-how-to-use-heat-set-inserts/
Also be wary of magnets
https://hackaday.com/2017/10/27/fail-of-the-week-accidental-demagnetization/#more-278311
I’ve used a soldering iron for this kind of thing for a 3D print and it worked well.
Please, clean up the soldering iron afterwards if you do this at the space, also, don’t do it on ABS.
np we have our own soldering irons was just after knowing if we had a press or someone had used one before we go ahead and 3D print one at home
