Dedicated mini cnc usb?
If you know where it is, would you please return it! Took a look around the space and didn’t come across is.
Despite the tendency of makerspace things to go walky, the mini cnc USB is not a real thing… Mainly since we have a shared folder. You can use any usb in the makerspace if the network connection is down.
That said, this is not an excuse to justify the behaviour… If anybody takes something and use it, they should ( i’d say must) put it back where they find it
Ah for some reason I thought I remember it being labeled.
The network connection isn’t a solution for me as I generally do my design on a personal machine, so I still rely on USB transfer.
We used to have a tethered usb… But it broke… And then the new sharepoint overcome the need ( when functioning)
