Generally cutting rock requires special bits and cooling and obviously we don’t have cooling on the Mini, but would it be ok for me to attempt to cnc some notches into some lava rock dry (with bits i buy)? (This would be for turning small rocks into table number holders for an event by adding a slit.)
At first glance the settings for a three flute carbide bit look achievable on the Mini (1000mm feed rate, 15k rpm), but idk about the torque of the motor.
Also, as I understand it from Joe, stone dust is terrible for machines and so that should be avoided in the space. Cutting outside is an option e.g. using the dremmel. With a circular saw attachment with diamond blade you might be able to do what you want with that, though doing by hand rather than CNC.
