Hi team, I’ve got a handful of aluminium extrusions I need to cut down to size and drill. Do we have an appropriate power saw and pillar drill currently up and running for metals use? If so, would anybody be willing and able to help get me to inducted status on these machines?
Very happy to reimburse with a six pack of your favourite beverage or otherwise!
Yep that seems to be bandsaw+drill press. We don’t have a formal risk assesment/induction as of yet, so I would have to supervise you. I’m happy to help whenever you’re in the space.
Kind of both! It’s a cheap chinese MGN Cube kit I’m converting into a Voron Trident that is going to have so many custom components that it will be hard to recognise as either.
@Oddstag - I’m likely going to use some alu extrusion in my project, so was excited to see you had been using it as well.
Do you have any tips on a good supplier of the stuff (perhaps as well as some slot-nuts), and are there likely to be any short offcuts if I search around in SLMS?
As for cutting and drilling, I guess I better get on the lists for the metalwork bandsaw and pillar drill! Hopefully I’ll just be able to get the lengths I need and simply use the slots…
