I have a bathroom tile that doesn’t quite fit. Is there a tool in the space that cuts through tiles?
Cutting a bathroom tile
There was a tile cutter belonging to @joeatkin2 in the snug…but we had the big clear out so I don’t know if it’s still there
Of course it’s still here! Bring your tile down!
Awesome, I’ll be there Wednesday. Is it dangerous, will I lose a thumb?
Not if you set up and use it properly! I’ll try be there, what time do you reckon you’ll be in?
I’ll be there at 7pm ish
I will buy you a pint if you manage to aputate with it .
WI’ll not cut flesh remember to put watter in it
@joeatkin2 hi Joe, is your tile cutter still in the space? I need to cut a few tiles into 10cm strips.
I’d like to use a tile cutter or glass cutter too.
should be
@joeatkin2. - could you give an idea of where your tile cutter might be found please. It’s needed for cutting a tile for the sublimation plate.
Bye no I did try under the wood in the toilet in arch2
