After several helpful suggestions, I’m thinking of trying to inject/fill my hollow 3D printed models with non-smelly clear epoxy resin instead of 100% infill at 11 hours per print! And I need about 10!
It’s usually about £32/Kg
Just wondered if anyone wants to chip in on 5kg at £95? Less than £20/Kg
Ultimately you could but this type of Epoxy as a really different viscosity and it’s much more like paint than the Epoxy you used I think. So despite sticking things together that it will definitely do when cured it will not have the strength resistance the 2 part epoxy counterpart have.
So I would not be gluing stuff together like from the hardware store, but using it to repair a windsurf board, so most likely over fibreglass matting. Something like this process:
